1 - 20 of 25 Posts
I've somewhat recently moved from the west to the east coast. Everyone here uses the plastic snap in connectors. I despise these things. Im used to 4040s, and no wholesaler here even has them. I get blank stares and fisher price connectors.. Ill have a box of L16s then.
The first electrician I ever apprenticed under swore by the 2 screw/lockring type of connector despite being more expensive. Ive done mostly commercial and industrial the past 8 years so I like the metal parts. Bias maybe. Is this plastic stuff the norm? What do you guys use?
4040s
in a pinch, L16s but they are not approved for loomex.
Those grey plastic pieces of **** can stay in the box.
The Arlington black ones work very well in some very limited instances,
Reactions: ohm it hertz
Not a plastic fan either. Removed lots, what a pain.
Residential Electrician
I like the two screw connectors for breaker boxes because you can adjust the cable in and out. I like the plastic ones for pancake boxes and feeding a new circuit into an existing panel because it’s lower profile and quicker. I like the 2 screw type for boxes that I’m running two cables through the same hole and plastic if it’s just one cable in the hole.
I think the 2 screw type are only listed for 1 nm cable. Arlington’s black push in plastic is listed for multiple cables.
Reactions: emtnut
Are you talking about connectors like wago? I've used them and like them.
Master Electrician - Ontario
I learned / was trained using L-16s until they were not approved for use with NMD90. Then switched to plastic, first the old 3360 connectors then to the 4004's. Once they came out with the other L-16 option that was approved for NMD90 I never switched back. While I prefer metal, I find the 4040's are just junk and scream DIY for some reason (like metal box offsets) to me. I keep a good supply of 808s (2-screw metal) in various sizes, but generally stay with the 4004s.
Cheers
John
Band Member
DIYer Extrodinaire
Cheers
John
So @wcord was right !
I never really used much Loomex for years (Industrial). Thought the L16s were always NMD/AC
Yep, you youngins don't know how much stuff has changed over the years lol
Reactions: Navyguy
1 - 20 of 25 Posts
