You could but it would look like trash.So how about if I have thhn 2 blacks, 2 whites, and a green. Then run them in the 3/4 seal tight about 50 ft long on the exterior of the home? With connector and 1900 boxes at each end? Theres nothing wrong with running seal tight 50ft on an exterior wall is there? Rather than pvc?
thhn is not rated for wet locations, unless dual rated thwn/thhnSo how about if I have thhn 2 blacks, 2 whites, and a green. Then run them in the 3/4 seal tight about 50 ft long on the exterior of the home? With connector and 1900 boxes at each end? Theres nothing wrong with running seal tight 50ft on an exterior wall is there? Rather than pvc?
Do they still make wire with only a THHN rating? Everything that comes from my supplier is rated for both. 50' of sealthhn is not rated for wet locations, unless dual rated thwn/thhn
When youre talking amongst your coworkers do u refer to thhn/thwn as such every time or do u simply say thhn ? this hack is contemplating slinging 50 feet of seal tight along someones house, and you attack THAT?360max said:thhn is not rated for wet locations, unless dual rated thwn/thhn
sleeving UF might be acceptable....~CS~I on this job for a homeowner who is selling and has violations. I have to run (2) dedicated circuits for the kitchen and bathroom outlets. My question is that it will be inspected and is it acceptable to run the (2) 12/2 romexs through the basement then to the outside wall into 3/4 seal tight just as a sleeve. No connectors. Just through the seal tight as protection for the cable. About a 75ft run with 3 90 degree bends. So exiting out of the home then entering into the home just as a sleeve?
should be acceptable, legally, but still ugly!:blink:sleeving UF might be acceptable....~CS~
sounds beautiful. Is the house decorated on the outside with snakes or something ?Attached is the picture I made quick
I have to question your claim of passing the EC test last year [ #1 ].. is it acceptable to run the (2) 12/2 romexs through the basement then to the outside wall ....
... out of the home then entering into the home just as a sleeve?
Laughed my drink up my nose. :thumbsup:sounds beautiful. Is the house decorated on the outside with snakes or something ?
