I dont think klein tools demolition drivers are suppose to do this!!!
The shaft on his goes all the way through the handle and is welded to the cap. It looks like the weld broke.Looks like they're not so different after all under all the smoke and mirrors.
On the plus side at least the tip looks to be holding up well.
buy one of thoseI have already contacted the wholesaler and they will get back to me. As for use just normal things tighting locknuts and busting out wood.
I suppose its a good thing that tang doesn't pass right through to the buttcap?I dont think klein tools demolition drivers are suppose to do this!!!
Ja, das wit look uber shexual next to my koloss in my toolhaus.buy one of those
Nothing worse than a tang passing through your butt-cap.I suppose its a good thing that tang doesn't pass right through to the buttcap?
*Edit I just tested mine and there is continuity between the cap and the shaft.
I agree. Screwdrivers are probably our most expendable tool. If I gotta spend 12 bucks every six months I'm not losing any sleep. Shít I used craftsmen drivers for years and all them bolts and strut straps are still tight I'm bettingsbrn33 said:you guys and your screwdriver fetish cracks me up. Klein makes a decent screwdriver. They hold up well to the abuse. So does Wira and Wera. They are no better or no worse. Abuse a screwdriver as electricians do and you will always have trouble.
http://i1000.photobucket.com/albums/af121/berniekerr/Waikiki Halloween/DSC02918.jpgyou guys and your screwdriver fetish cracks me up.
Did you talk to the wholesaler to get another under warranty? They did it for me buddy.farlsincharge said:I broke mine today the exact same way (weird). I noticed the cap was spinning. I do beat the ever loving jesus out of it though.
