1 - 17 of 17 Posts
Here we go again
Rooftop AC unit
MCA is 45.2A (manufacturer)
125% of that is 56.5A
Ampacity is 65A (according to 310.16 @ 75°C)
Conductor is 6 AWG
MOCP 70A (manufacturer)
How do I protect this
a) 60A Safety switch with 60A Fuse
b) 60A Safety switch with 70A Fuse
c) 100A Safety Switch with 70A Fuse
Electrical Simpleton
Here we go again
Rooftop AC unit
Conductor is 6 AWG
8 awg wire... 60 amp non-fused disco... and a 50 amp HACR rated circuit breaker.
Pete
8 AWG? How can that be?
With a MCA of 45.2A the branch circuit would be loaded above 80% since 8 AWG allows for 50A max at 75°C
Sorry, I failed to pay attention that you are in Canada... perhaps things up North are different...
In the US what I stated would be compliant.
Pete
I'm not, just using familiar reference
But... I still don't get it
Could someone explain that 8 awg selection
From what I know, the MCA listed by the manufacturer already includes the 125%. Therefore, the MCA ampacity you have given would be acceptable on an 8 awg conductor in a raceway.
Pete
Electric Al
Nope, and they should not fit anyway.
A F A I K That is correct .
There are many different styles of adaptors , but they can only be used to fuse down .
You can , of course employ fuses that are engineered for different applications and varied uses ... eg ; slo-blo , H R C etc.
Therefore option b) is not possible
Option a) is the big winner?
If it were my money I would just use a 60 amp non-fused disconnect at the RTU and a 60 amp HACR rated CB at the panel. With 8 awg cu wire all the way.
But, if the nameplate calls for "fuse only" protection you will be stuck with them.
Pete
1 - 17 of 17 Posts
