1 - 2 of 2 Posts
When you fill out the st-50 quarterly form, do you put down $0 in the gross receipts column if all your work is new install and no repair...?thanks
Yes. If its zero then by all means put zero in the box. Just make darn sure you're right. Have the customers sign the ST8 confirming that its a capital improvement. If they won't sign it then charge them the tax and hand it over.
1 - 2 of 2 Posts
