What do you do for a panel tune up? Set the correct torque values?offer big ticket items
whole house device replacement
panel changes. panel tune ups
lighting packages
multiple branch circuit microwave and other load you see that are overloaded
Clean the door off with a wetnap. Snake oilAllWIRES said:What do you do for a panel tune up?
Okay, sounds good. Now how do you flat rate it? 2.5 labor hours?Act like you're trimming the panel on the initial install. Re-torque, re-tag, split double taps, trim excess wire, check lock nuts, legibly rewrite schedule (re-tracing extra), vacuum, etc.
Add-ons:
Check for adequate grounding
Re-trace schedule
Surge suppression device(s)
A Panel Restoration is a great money maker, it generally doesn't take any new material, so you're selling your labor. You really shouldn't have much trouble.
Edit: anytime you "need" to open a panel you should be selling this to your customers. Walk him/her down and show them exactly what you're going to do. "ALWAYS BE CLOSING" ~Glengarry Glen Ross
Anybody can sell a receptacle or light fixture. Where you'll make money and build your reputation is on the services you can provide. You're better than the next guy because of your expertise, scheduling flexibility, services provided, warranties, and your professionalism.
Don't let anybody tell you differently.
30-40 space: first panel at 2.0 any additional at 1.5Okay, sounds good. Now how do you flat rate it? 2.5 labor hours?
:laughing: :laughing: :laughing:Act like you're trimming the panel on the initial install. Re-torque, re-tag, split double taps, trim excess wire, check lock nuts, legibly rewrite schedule (re-tracing extra), vacuum, etc.
Add-ons:
Re-trace schedule
there corrected it for you:laughing:Clean your butt off with a wetnap. Snake oil
I haven't yet called bullish. I'm totally on the panel tune up wagon right. Thanks for the information, seriously.Lep said:panel inspection tune up: inspect buss check breakers reconnect, re torque wires dress aluminum wires id circuits on list of door inspection of panel components code violations take before and after pictures Etc., we charge 175 per. if you think its BS don't bother, you're the one asking for sales techniques.
I'd say electrician is almost compelled to look in those panels, are you going to know what condition panel is in without at least take a look.I haven't yet called bullish. I'm totally on the panel tune up wagon right. Thanks for the information, seriously.
I open the panel 98% of the time. Just never thought about the tune up. It's the perfect sale to a tough customer who won't pay for a full change.Lep said:I'd say electrician is almost compelled to look in those panels, are you going to know what condition panel is in without at least take a look. but some guys like to change a light bulb and then run out front door call it good
If they won't pay for a full change, does it even need to be changed? If it needs to be changed, change it. If it doesn't, and the panel is just messy, then why? If it ain't broke, then why fix it?I open the panel 98% of the time. Just never thought about the tune up. It's the perfect sale to a tough customer who won't pay for a full change.
