In a apartment building I installed a subpanel in the apartment that is being renovated (these are small studio apartments). The main panel is in the basement of the building. The whole apartment is wired from the subpanel except for one outlet which is by the window which is dedicated from the main panel(Exisitng). The room where this outlet is in is the bedroom, I ran two 20A circuits in this room(since it's a studio, it's really a living room and bedroom).
My question is, should I leave that circuit there? I feel like if the tenant wants to turn off the power in the living room they will go to the panel and turn off the breakers thinking that all of the outlets are off in the living room but since that outlet is from a dedicate circuit from the basement it will be on.
Thoughts?
Should I take out the dedicated circuit from the basement? (Anyway it's not AFCI).
Should I just put a label on the outlet faceplate indicating that it is fed from main panel?
Are there code references for circuits being labeled if derived from the main panel as is in this case?
Thoughts?
