1 - 7 of 7 Posts
A friend called me with strange voltage readings from his server PDU outputs.
Friend: This is strange, the building is wired for 208, yet I get 120V from 2/3 of the PDU output cords and 230V from the remaining 1/3. On the input side I get X to Y 240V, X to Z and Y to Z 120V, and Z to ground of 0V.
Me: You can't get 240V from 208V unless there is an additional transformer somewhere. Please look at the power pole and tell me what you see.
Friend: One transformer with three secondary windings and two smaller identical transformers with each two secondary windings. They are delta connected and 4 wires go into the building.
Me: Cool, when was the building constructed.
Friend: 1963 Why?
Me: 240 high leg delta was popular then.
I only bring this up so that we check the voltages and understand the building power system before plugging in a bunch of expensive servers and causing a lot of smoke.
Hackenschmidt
PDUs are almost always plugged into a UPS, and a lot of UPSs will take 208 in and make 240/120 out.
I have seen PDU's that put out both 120v and 230v. Best to have your friend read what the input and output of the PDU says.
IBEW 6 volts to lightning bolts
Strange. Most PDU setups are fed via UPS with 3 wire 480 or 208. The XFMR within the PDU will give you 120/208 on the output stage.
Hackenschmidt
There are a lot of PDUs that are not that fancy, really just a fancy outlet strip.
Tool Office supplies Automotive exterior Font Auto part
1 - 7 of 7 Posts
