Status
Not open for further replies.
1 - 5 of 5 Posts
Hi
I am assessing the existing 600a 3 phase 240v delta service in an shop
To we there is room for addition
Looking the utility bills that say 120 kW or 300A @ 240v 3ph maximum demand worst case
If Each leg at overhead(service drop) draws 100A assuming all legs balanced
Than I have big room for new loads
New load : 600A @240v 3 ph. 200A on each leg
What is the real capacity?
Any room for adding 600a load??
· Premium Member
Hi
How long have you been in the industry ?
· animal lover /rat bastard
Hi
your profile says you are an electrical contractor.
clearly you are not.
why did you lie ?
· Premium Member
Just a note until this gets resolved.
200A on each leg is NOT 600A @ 240V. It's 200A @ 240V 3-phase.
If you called it 600A @ 120V you'd be technically correct, but it's simply not stated that way.
1 - 5 of 5 Posts
Status
