When doing a service that requires a disconnect on the exterior, how do some of you do your grounding? For instance on QO 100 amp disconnect they only have lugs for the neutral and one ground. What do you guys do with your water ground and ground rod? I usually add lugs to the case of the disconnect via a 1/4x20 bolt and take my water ground through that and land it on the one supplied ground lug then take the SER ground and ground rod to the other 2 lugs off that same 1/4x20.. Is this code compliant?
http://m.homedepot.com/p/Square-D-b...O2100-Breaker-Included-QO2100NRBCP/100172670/
