1 - 15 of 15 Posts
I'm remodeling my kitchen and am bringing it up to code. My service is 120/208. I wired up my first multiwire circuit. I decided to read neutral current flow with a clamp on ammeter to make sure everything was cool. I had a 1 amp load and a 2 amp load on the two hots. I expected to see something less than 2 amps on the neutral but was surprised to see the full 3 amps. The hots are fed from opposite busses. Can anyone help me figure this one out?
Thanks,
Don
Salty Member
When using just two hots of a three phase supply the neutral current is about the same as the currents on the hots. This is because the hots are 120 degrees apart not 180.
Salty Member
Here is a code section that relates to it
310.15(B)(5)(b) In a 3-wire circuit consisting of two phase conductors
and the neutral conductor of a 4-wire, 3-phase, wye-connected
system, a common conductor carries approximately the same
current as the line-to-neutral load currents of the other conductors
and shall be counted when applying the provisions of
310.15(B)(3)(a).
In your example (1A and 2A) the neutral current should be about 1.7A
So, if each of the two circuits are drawing 20amps each, the neutral would have approx. 22amps?
Actually, it would have 20 amps.
In = SQRT((Ia*Ia+Ib*Ib+Ic*Ic)-(Ia*Ib+Ib*Ic+Ic*Ia)) (posted after BBQ did below)
Discussion Starter · #14 ·
Troubling Update
After more thorough testing I am even more troubled.
Quick recap: My service 120/208, hot to hot is 208.
With an 8.5 amp toaster oven on one circuit and 11 amps on the other circuit which feeds the fridge (about 1 amp) and space heater (temp) my neutral current reads 19.2 amps. I'm using an Amprobe ACD-15 Pro clamp on ammeter. This condo has been wired with mostly MWBCs ever since it was built from what I can tell. Have the neutrals been overloaded the whole time?! I'd really like to get on the feed to my panel which is just a subpanel but I just don't have the room.
Thanks,
Don
Discussion Starter · #15 ·
It's always something stupid and simple...
I'm both embarrassed and happy to say that after further troubleshooting I discovered that the outlet we wired temp for testing was miswired and being fed by the wrong circuit. This led to all loads being on the same leg. I was a little lazy in my initial troubleshooting and made too many assumptions. One assumption was that there was a problem in the first place.
I think the initial problem I saw with the 3 amp neutral was simply due to low inductive loading along with meter creep.
Final Reads Ignoring Fridge (<1 amp) which is always on:
CKT 1 on 2 off - In=9.1A
CKT 1 off 2 on - In=11.9A
Both CKTs on - In=12.0A
Thanks for the replies.
1 - 15 of 15 Posts
