In a nutshell NO. All insulated (class 2) here in the UK are supposed to be ALL INSULATED.
Your problem may not be a direct earth fault but some capacitive/inductive voltage that is a feature of the on board electronics. DVD units operate from a 12/24 volt secondary supply via an isolating transformer - so the shocks should not be mains born as mentioned. Check with a load of some sort - say a table lamp to neutral and check if the lamp takes any current via in line amp meter. If not then seal the protruding screw head. Otherwise throw away 'cos they are not worth fixing
