Found this unusual install today.. believe it or not I think this was actually approved at one time the fixture was all porcelain with rubber seals
Yes it is. Hippie responded but as often happens with smart phone they hit report post instead of reply post. His response was yeapI assume the shower is being re-tiled?
Yeah not sure how I did that. Its getting new tile so I didn't worry about cutting itYes it is. Hippie responded but as often happens with smart phone they hit report post instead of reply post. His response was yeap
I also fixed a receptacle that had caused a phone charger to burst into flames at another house today. It was backstabbed AND in a blue carlon box![]()
The only thing worse than that is backstabbed device with aluminum wire in a 14 cubic inch brown bakelite box protected by an FPE or Zinsco breaker. :jester:I also fixed a receptacle that had caused a phone charger to burst into flames at another house today. It was backstabbed AND in a blue carlon box![]()
If you have to ask that question, you should probably just move :laughing:I wonder how much they would charge to clean my shower?
Squeaky clean. :laughing:that is pretty clean, isnt it?:thumbup:
Is the shower light gfci protected? or is that not required in your area?Replaced with new shower can
Room was too narrow to be able ro get the whole shower in the picture, I tried to though. The bottom of the original fixture was less than 6 feet off the floor. And the floor was none to clean they needed to scrub with some serious bleachthat is pretty clean, isnt it?:thumbup:
