41 - 52 of 52 Posts
I am told that for a panel to be rated for tandem breakers it must have a neutral screw for each circuit. So 40 circuit panel would have 80 neutral screws to be rated for tandems.
I own stock in FotoMat!
Why would 40 circuits have 80 noodles? Or are you counting grounds as well?
Either way, I've rarely seen panels with a 2:1 neutral bar ratio.
But that may be a Canadian thing as well, eh?
I got to thinking about making the sub a 120 volt panel, and call it a day.
A 40 amp single, with 8/2.
Load is a small shed, a pond pump and another circuit for convenience.
Thoughts on that idea?
cough*hack*cough
Just double up something.
Discussion Starter · #44 · (Edited)
seimans panels
I am not saying that the breaker will burn down the house. It's the point that if it happens they will come looking. I might agree that you could do in an emergency but change it after that. A real contractor looks to do it right the first time and safely.
child please.....
Ok, Ok. I agree with that. I don't go out of my way to install the wrong materials. Sometimes, you have a cheap customer that wants it done as cheap as possible. It is an inexpensive way to add a circuit(if he couldn't double up on some existing circuits).
It is your choice, however the Insurance Investigator will be glad to talk with you if there were to be a fire
If there is one thing I've learned on the internet, it's that a lot of people worry WAY more than I do.
This whole CTL / non-CTL business would be a lot easier to deal with if manufacturers would label the panels on the outside (i.e. on the cover) as to what it's designed for. As far as I can tell, in order to figure out what kind of panel I'm dealing with (e.g. 30/30 or 30/40) I have to take the cover off, pull some breakers above and below, and examine the stabs. Slows down the estimate considerably. Should be printed on the box somewhere.
And I know: covers, where the labels are, can be swapped around. Still: they're engineers. They should be able to figure out something.
41 - 52 of 52 Posts
