Normally when providing a circuit for the sign installers, I always provide a disconnect, even if the sign has its own disconnect on it. Everyone around here does it like that, probably from assuming the sign would have its own disconnect and then failing inspection because it doesn't. Its basically just a habit, but most guys do it like that here, and it keeps you from running into any problems if you provide the circuit before the sign guys show up.All the ones I've wired up had a disco switch built in.
I was only asking the question since now that most new signs are low voltage LED , is a switch really necessary. I notice many new signs going in without a service switch. I'd like to join them if I could.Normally when providing a circuit for the sign installers, I always provide a disconnect, even if the sign has its own disconnect on it. Everyone around here does it like that, probably from assuming the sign would have its own disconnect and then failing inspection because it doesn't. Its basically just a habit, but most guys do it like that here, and it keeps you from running into any problems if you provide the circuit before the sign guys show up.
I haven't done any LED signs yet. Interesting...maybe there is some sort of in-line quick disconnect, kinda like what they put in fluorescent lights??I was only asking the question since now that most new signs are low voltage LED , is a switch really necessary. I notice many new signs going in without a service switch. I'd like to join them if I could.
The last sign I supplied power to I installed a gfci outlet with an in use cover. I was informed that the sign guy would be doing his own wiring and he did so smoking his drivers by wiring the outputs as the lines.I haven't done any LED signs yet. Interesting...maybe there is some sort of in-line quick disconnect, kinda like what they put in fluorescent lights??
