So I have these two thermoelectric coolers, they are small like 2in square, one side gets hot one side gets cold. they are 12v and 90w. now one works fine, but when I splice two together they both brick, they both stop working.
obviously the current is doubled to them that's why they brick, but why? how do I fix this. how do I splice into power without a separate power supply, how do I utilize the same 12v source? do I need to add more ground?
here's a simple drawing diagram. can someone help? I'm sure it's a simple electronic theory I'm not sure about here.
https://imgur.com/T6ZhbL6
do I need to add a resistor or something simple? why does the current double to each cooler? why doesn't it split where the wire is split?
