Hi all,
I am about to take my Journeyman electrical test on Saturday. I have been going over the NEC and trying to figure out these calculations. I really need help on this one I just cant figure out where some of the numbers came from or how they determined what to use. I am sure I am just over looking something.
Single-Family Dwelling Service Load Example
The dwelling has a floor area of 2000 ft 2, exclusive of an unfinished cellar not
adaptable for future use, unfinished attic, and open porches. Appliances are a 12-kW
range and a 5.5-kW, 240-V dryer. Assume range and dryer kW ratings equivalent to
kVA ratings in accordance with 220.54 and 220.55.
Calculated Load [see 220.40]
General Lighting Load: 2000 ft 2 at 3 VA per ft 2 = 6000 VA
Minimum Number of Branch Circuits Required [see 210.11(A)]
General Lighting Load: 6000 VA ÷ 120 V = 50 A
This requires three 15-A, 2-wire or two 20-A, 2-wire circuits.
Small Appliance Load: Two 2-wire, 20-A circuits [see 210.11(C)(1)]
Laundry Load: One 2-wire, 20-A circuit [see 210.11(C)(2)]
Bathroom Branch Circuit: One 2-wire, 20-A circuit (no additional load
calculation is required for this circuit) [see 210.11(C)(3)]
Minimum Size Feeder Required
[see 220.40]
General Lighting = 6000 VA
Small Appliance = 3,000 VA
Laundry = 1,500 VA
Total = 10500 VA
3000 VA at 100% = 3,000 VA (I dont get this one!)
9000 VA - 3000 VA = 6000 VA at 35% = 2625 VA ( or this one)
Net Load = 5625 VA
Range (see Table 220.55) = 8,000 VA
Dryer Load (see Table 220.54) = 5,500 VA
Net Calculated Load = 19125 VA
Net Calculated Load for 120/240-V, 3-wire, single-phase service or
feeder
feeder
19125 VA ÷ 240 V =
79.7 A
Sections 230.42(B) and 230.79 require service conductors and disconnecting means
rated not less than 100 amperes.
Calculation for Neutral for Feeder and Service
Lighting and Small Appliance Load = 5625 VA
Range: 8000 VA at 70% (see 220.61) = 5,600 VA
Dryer: 5500 VA at 70% (see 220.61) = 3,850 VA
Total = 15075 VA
Calculated Load for Neutral
15075 VA ÷ 240 V = 62.8 A
