1 - 3 of 3 Posts
Swimmer
1. Which article best spells out that ground is connected to neutral in only one place, e.g. not in sub-panels?
The best I've seen so far are 250.24(A)(5) and 250.142(A) Now I understand why so many installers get this wrong.
2. Is a typical residential service a separately derived system? I'm thinking yes because:
A: The same system bonding rules apply
B: There is no physical connection between neutral input / output at the transformer on the utility pole.
2A- The rules are close, but aren’t the same.
2B- The neutral connections are together on the pole mounted transformers I’ve seen.
Reactions: swimmer
Art 230 is on services & SDSs have their own definition.
SDSs can be
1) stepdown xfmrs (not services),
2) UPSs,
3) generators
(all three depending on how they're wired).
Reactions: swimmer
1 - 3 of 3 Posts
