1 - 12 of 12 Posts
Sewer lift station, has 2hp motor drawing 8Amps on one leg and 27 on the other. The cable is in great shape. I used a megger and my windings were good I'm curious what else it could be?? Their is a capacitor and that's good also.
Did you megger the motor directly, or from the control box? Maybe a wire is frayed somewhere, I would megger from the control box and see if it's good from there.
2hp?8 amps? this is not even possible let alone 27amps. do you have a circuit breaker there? what's the temperature of your motor? if everything thing is ok I would change my clamp meter battery.
Donuts > Fried Eggs
What's it doing that made you troubleshoot it to start with?
Current is never lost in a system, so on a two wire feed that's working properly you've gotta have the same amount of current on both legs. If you truly have an imbalance like that, you have a winding ground-fault and that's where your extra current is going.
How'd you meg it?
The overloads were making the starter trip out. The megger the had was an old wind up, there was two setting megg-ohm and ohm. I used ohm and it was mostly towards infinity. There was two sets of wires going to the motor i did each one maybe the megger is bad. Do you think that a fluke 179 is good enough on the ohm scale? Knowing we don't have another megger?
The motor is down in a whole. The feeder goes to a terminal bar, to capacitors then to the starter. The starter is so old the thermals look like springs. Not really used to seeing that but. I do agree that it is a winding just wish I can see it . Everything mechanical is good so.
You need to use the mega ohm setting.
Electric motors can and do show faults only under full working
conditions ! that dont show up on a meggar test !
Dont diss-miss the notion of a faulty motor just because a digital
testing meter says " OK ".
Called intra winding short ! or intermittant fault !
Most experienced motor electricians will back up that one !
The 179 doesn't have a megger feature, that is just a setting to allow you to show high resistance values. You need to get an actual megger that has a power supply to properly check windings. Just reading resistance isn't going to give you the right info.
Beat me to it...
A 179 is powered by a 9VDC battery, it is not going to show you anything useful in a motor winding.
You said you had a wind up megger right? Use it on the Megohm setting. Using it on the ohm setting will make a typical insulation leak look like nothing, which is what you saw.
Actually use the megger and do an insulation test and report back.
Check for a J-box inside the wet well too, those like to get filled with poo water and leave you with a big melted/corroded ball of wire, wire nuts and poo. :laughing:
1 - 12 of 12 Posts
