I have three identical exhaust fans on a job, two of them work, but the third instantly tips the breaker in the starter cabinet when I try to turn it on. If I disconnect the wire to the motor the circuit is fine so I know it's in the motor.
Both capacitors are good after checking with my meter, no impedance when spinning the fan by hand, winding is not shorted to ground, 0.8 ohms when I read the winding. What am I missing that is causing the breaker to trip? Thanks in advance for any help
