1 - 20 of 31 Posts
IBEW L.U. 1852
Its broken for sure.....most likely the start cap if one exists......if not the centrifugal switch for the start windings is likely fubared.
Certified Organic A-Hole
Can it be just a bad capacitor? I know single phase motor needed a push unlike 3 phase motor. Like capacitor with start winding? I think it's called a centrifugal switch or something like that.
Yes it could be just a bad cap. The centrifigual switch is what drops the start cap and winding out when the motor reaches speed.
See if the cap is blown out, or has oil leaking out if it it is bad, but they can also go bad and not show any signs of it. I would take the back endbell off and look at the stationary switch as well, you can do that while the motor is in place. If it is a switch problem 9 out of 10 times its the stationary switch not the centrifugal.
1 - 20 of 31 Posts
