I can't make heads or tails of this.. is it real or fake or just nuts?
It's used in the US too. I've seen it in a few rural areas. Easy to spot the single HT wire with a drop to the xfrmr.Sounds a bit different from the old "skeleton" service, which was used in rural areas 100 years ago -- a single HV wire, using the actual ground for the return.
So, is like US news?I don't think 'the peoples news' over there is entirely factual....:whistling2:~CS~
They are lighting a 100 watt bulb using 2400' of earth for the return path.CS, WTF am I looking at in that photo...?
I had trouble with the translation because when the newsgirl was speaking, I wasn't watching the subtitles. :no:I can't make heads or tails of this.. is it real or fake or just nuts?
http://www.youtube.com/watch?v=zcvSXQHvFLg&feature=youtu.be
