So my internet connection is running slow even though I have "high speed internet". My ping is usually 10-20 ms which I'm told is good. I have a Dell Inspiron 1525 and recently did a factory reset. So whats the deal??!
What other information do you need? I told you my ping and what computer I have..Deep Cover said:Your profile states that you are an electrician. If that is the case, you should know that nobody is going to be able to help you with the little information you have gave us.
Hard wired. Internet explorer is awful. Firefox is a little better. Im guessing its my laptopdrspec said:Are you using a wireless router or hardwired connection? Have you tried a different browser?
I have a modem which goes into a netgear switch. No wireless router. Hard wired from netgear switchCADPoint said:wi-fi or hard wired? Can you look at your router with software?
Try a new cable?I have a modem which goes into a netgear switch. No wireless router. Hard wired from netgear switch
How old is the laptop?Hard wired. Internet explorer is awful. Firefox is a little better. Im guessing its my laptop
The laptop is 5 years old. The cable between the netgear switch and my laptop is fine. I tested itdrspec said:How old is the laptop?
Is there anything else connected to the switch?The laptop is 5 years old. The cable between the netgear switch and my laptop is fine. I tested it
The netgear switch has 10 ports. I have my xbox plugged into it but its not currently on. Im just going to buy a new laptop loldrspec said:Is there anything else connected to the switch? I'm with Dennis, connect directly to the modem and see what you get. Also, how old is the modem?
How is the connection on the Xbox?The netgear switch has 10 ports. I have my xbox plugged into it but its not currently on. Im just going to buy a new laptop lol
Very good.drspec said:How is the connection on the Xbox?
I was having a problem with my connection a few months back. It would work great for a few minutes then would drop the connection.Very good.
Modem is brand new and my xbox connection is great. I think my POS dell laptop just needs to be replaced. Thanks for repliesdrspec said:I was having a problem with my connection a few months back. It would work great for a few minutes then would drop the connection. Turned out to be the modem.
