1 - 20 of 23 Posts
Do you guys have a preference on hard wired smoke detectors? BRK or Kidde Firex?
I've been having a lot of call backs and issues with BRK lately.
I had over 50% failure rate with Kidde Smokes/CO2 detectors. I've had no problems since switching to BRK. We are not the only contractor in the area that has issues with Kidde. one supply house said a contractor brought back a 50 gallon drum full of Kidde detectors that had recently been installed on a large project.
Can't Remember
I prefer the BRK combo photo/co units. Lots of the equivalent Kidde ones have been replaced at the housing units I work at. Have to install a new smoke circuit for one of my generator customers and going with BRK.
Sideways Sparky
Lots of callbacks with kidde lately. Seems the battery backup units like a name brand fresh battery, not the junk they come with.
Quite a few reacting to "high" humidity as well.
Not a lot of choice here, supplier sells kiddie.
Haven't had a lot of trouble. Other than HO has to do monthly test or the unit will switch over to battery power and run battery's dead and start beeping. I learned that the hard way!
I didn't see that on the info sheet .
Now I tell them to change batteries and test them first before I go on call
Wow 50 % failure , I would change to. That's ridiculous. Did you contact the company?
Can't Remember
I have put in a couple of the Nest ones but they haven't been in long enough to know whether they are worth the bucks.
Haven't had any huge problems with any of the major brands. I've had a couple bum one's here and there from all of them. Locally, I get Kidde easily, so that's what I tend to use. It's nice to get a failed smoke detector call and be reasonably assured what brand I installed there so I can make sure I have one along on the truck. I try to make it a point to tell people to use a good, major brand battery and resist the urge to buy the dozen-pack or 9 volts from the dollar store.
The supply house brought in a rep, who stated they didn't have a problem. Then later asked a contractor that had been in business for over 20 years, if they had been installed properly:eek: Kidde has been a major problem in this area.
Installed properly? WTF is it rocket science !
Nice blame the contractor that will get you lots of repeat business
1 - 20 of 23 Posts
