1 - 20 of 45 Posts
Homer to Jebus
Electron Flow Consultant
Forgot to take pictures today will tomorrow.
My question is, is it legal? :laughing:
Reactions: Shockdoc
Homer to Jebus
Does it take longer to do. I would think stripping the romex and then the wire would be a pain.
Haven't stripped it in. I usually wait until the painters are done. :)
Reactions: caraz
Retired Account
Not really
For instance, 4 pieces of romex going into a 3 G nail-on box might all be on one stacker, and be cut in all at once, and in an order that would allow for said loops (if needed) to be pulled into the box w/o twist of hangup
Homer to Jebus
Reactions: guest
felonious smile.
If any of my guys did resi work that looked that bad I would send them to the commercial crew.
What looks bad? You didn't see the final stage
Reactions: guest and sbrn33
felonious smile.
What is the advantage of this? Why not just stab your wires into the box, make up your grounds and be ready for trim?
a continuous run, less chances of a terminal failure, less waste, less material such as greenies, once a custom to, less time.
felonious smile.
Shock is a penny pinchin miser with material and labor. Every little drop in the bucket helps when you have to haul ass to be competitive.
Inspectors always seem to be impressed with this method. I had one mumbling over 3 two wires under a staple, he the investigated a few outlets, said nothing and placed a green sticker in the window.
Reactions: guest and 3xdad
felonious smile.
Im gonna spice it up with some on the job pics
Reactions: That_Dude
1 - 20 of 45 Posts
