I suppose you'd have to read the specs for each, and see if they both trip at the same milliamp level. Or, use an RCD tester, such as was represented in another thread earlier, and see if they both trip at the same level.Hi friends, can you help me with this issue:
How did you confirm that sockets with RCD, met the requirements for a circuit with RCD?
