I have solar and I'm none of those. I guess that makes you, WRONG again!FrunkSlammer said:Solar is for hippies and liberals and vegetarians.. or otherwise known as Hipperaltarians.
Solar System- 8 some like to think 89 planets rotate around the sun, the Earth (where everything in the Universe is grounded) takes approximately 365 days to make this trip.
Or re-instate Plutofree Pluto now !
Interesting that we bake in the sun down here in Florida and Solar setups are as scarce as hens teeth.I have solar and I'm none of those. I guess that makes you, WRONG again!
Solar systems are far more efficient in the cold.Interesting that we bake in the sun down here in Florida and Solar setups are as scarce as hens teeth.
We have very little NG here too.
True but it might be a wash with the better angle to the sun down in FL.Solar systems are far more efficient in the cold.
Without a compass that tree line could just as well be completely irrelevant....why install the panels so close to the tree line, your losing valuable sun?
BTW, without the rebates (Gov't handout), solar is a loser
How high does natural gas and coal need to get before solar is competitive?...why install the panels so close to the tree line, your losing valuable sun?
Well then, I guess Obama lied.Two thousand new shops full of "solar" electricians that only know pvc glue and pull four #10 to a disconnect then drive a ground rod are loosed upon the populace.
Lord, I hate the smell of patchouli.wildleg said:I call shenanigans. that mountain is probably crawling with tree hugging hippies
didn't even know what it was (except by smell). had to look it up lol.Lord, I hate the smell of patchouli.
Incense[edit]
Patchouli is an important ingredient in East Asian incense. Both patchouli oil and incense underwent a surge in popularity in the 1960s and 1970s in the US and Europe, mainly due to the hippie movement of those decades.[10]
Toys[edit]
In 1985 Mattel used patchouli oil in the plastic used to make the action figure Stinkor in the Masters of the Universe line of toys.[11]
If you have ever been to a Dead or Phish, maybe Dave Mathews show you have smelled it.didn't even know what it was (except by smell). had to look it up lol.
