#10 ground and you need GFCI protection for the hot tub
Thanks! That's what I'm understanding also... what about a service plug? I don't see that there is a requirement for that... just would like to be sure.#10 ground and you need GFCI protection for the hot tub
Wait a minute. #10 equipment grounding conductor but a #8 for the equipotential bonding.#10 ground and you need GFCI protection for the hot tub
This is true but once the hot tub is installed outside then part II applies-- 680.42I did browse through 680 on this. Part 1 and part 4 apply to my installation as far as I know.
Ok thanks! I'll definitely take another look at that. I just checked the manufacturer's instructions (the customer just sent them to me) and they do in fact require a number 8 grounding conductor. So much for using romex!This is true but once the hot tub is installed outside then part II applies-- 680.42
I hope I don't sound stupid here, but it would be more stupid to perform an incorrect installation so I am going to ask. Does the equipotential bonding conductor, (if one is required), have to go all the way back to the panel or can it be connected to the ground conductor for the circuit supplying the spa?Don't confuse the equipment grounding conductor with the equipotential bonding.
All the way to the panel, I think you can also hit the GE or GEC.I hope I don't sound stupid here, but it would be more stupid to perform an incorrect installation so I am going to ask. Does the equipotential bonding conductor, (if one is required), have to go all the way back to the panel or can it be connected to the ground conductor for the circuit supplying the spa?
Not wanting to argue with you, (I am interested in code clarification only), but 680.42 states "A spa or hot tub installed outdoor shall comply with the provisions of Parts I and II of this article, except as permitted in 680.42(A) and (B), that would otherwise apply to pools installed outdoors...." Then in the provisions for 680.42(B) it lists the conditions.This is true but once the hot tub is installed outside then part II applies-- 680.42
You did. I'm not sure the OP was reading what you wrote..
I believe I mentioned all this before.
Yes, I probably overlooked what was said earlier, or didn't quite put everything together.... But, thanks everyone for the answers. It is definitely worth it, for me, posting here.You did. I'm not sure the OP was reading what you wrote.
Pete
Now it's my turn to question. Since it is outdoors and now part II of 680 applies to this isn't the nmb out of the question now for any part of this not running on the interior of the building? (might be on the far side of the deck away from the exterior wall of the dwelling) OP mentioned he was going to run nmb for his hot tub.
