1 - 8 of 8 Posts
I have a 11 KW pump. the wiring is in a star-delta pattern. obviously, i have to use 3 contactors. what is the value of the current in each contactor first of all, in the start and then in the running of the pump?
I can name that tune in two contactors.
Any reason why you wouldn't use a pre-made star-delta starter with the timers and all, or just put the darned thing on a VFD to begin with and be done with the archaic start arrangement?
Shame on you. As an ENGINEER, you should know better than to ask a question without giving enough information to be able to formulate an answer.
I am an electronic engineer, not an electrical engineer.
i'm specialized in programming, and handling PCBs.
nevertheless, i was just asking to learn more on how to work with pumps.
I am an electronic engineer, not an electrical engineer. i'm specialized in programming, and handling PCBs. nevertheless, i was just asking to learn more on how to work with pumps.
So does that mean you don't work with formulas? You gave 1 value, 11 KW, and want to calculate current. This is something that you do in electronics as well, don't you? What is the voltage for a start?
Look at the motor name plate for Star (WYE) Current and Delta Current
Star is the first current and the Delta is the second
Good luck
I think I would struggle trying to figure out where to fit a third contractor into the start sequence.
How old is this motor, is it in service now or has it been, has it been tested/ meggered, what voltage is your system?
You will have 3 contactors. 2 of them (Start and Run) can be sized for 58% of the current, the other (Star) at 33%. But as others have said, don't over think this. Sometimes there are other issues such as mechanical interlocks that are necessary do not work on mis-matched contactors so you end up with all 3 being the same size, it totally depends on the contactor mechanical designs. Just buy a pre-made star-delta motor starter, the manufacturer takes care of all of that for you.
1 - 8 of 8 Posts
