1 - 8 of 8 Posts
I figured out today that a step bit works awesome for de- burring rigid conduit! Who would have thunk it!
IBEW L.U. 1852
It actually works well for reaming or deburring any conduit as long as you dont try to ram it through the conduit. I will caution that I have found using a stepper for that purpose seems to dull the bit fairly quickly.
They also blast thru TJI engineered floor joists, and particle board in general without jerking your drill around like a paddle bit or auger does.
Was doing a basement Reno a while back, plumber was there adding some lines, I watched him for a bit drilling his holes through the 2 by floor joists. He spent a while drilling his holes because he was using a step bit. After he was done I pull out my auger and drilled my holes in a few minutes.
Looks at me, "that's quicker". I said yep, want to use it?
Anybody have issues with the greenlee ones? I was using one at the local staples and dropped the bit from about 2 - 3' while cleaning up and shattered the bit. The tile was not even high quality ceramic tile floor. Bit was not that old, maybe just faulty?
IBEW L.U. 1852
I never had that happen with any Greenlee bits but they didnt seem to keep an edge for very long. I buy Lenox stainless steel ones now and have zero issues so far.
1 - 8 of 8 Posts
