1 - 1 of 1 Posts
felonious smile.
Got a call to pole service for a house lift. I wired it 110 volts into this ml of a 4 circuit panel with two breakers and gfci s. When the compressor kicks on, line voltage drops to 90 volts.
I had them put call into poco, I suspect resistance on noodle of corrosion inside drop.
1 - 1 of 1 Posts
