Thanks 480 I had the instructor go over it when I was in an exam prep but that wasn't important so I didn't remember it.If you have all 14 numbers, that means you have the First Printing. Once they go to Printing No 2, the 1 disappears.
Round 3, 1 & 2 go away.
It's important when it comes to errors. Testing companies will capitalize on them by creating test questions that refer to errors. If you don't download the Errata, you can get the question wrong even though your book says you're right.Thanks 480 I had the instructor go over it when I was in an exam prep but that wasn't important so I didn't remember it.
I passed the New Jersey Exam, I'm good for now! :thumbup:It's important when it comes to errors. Testing companies will capitalize on them by creating test questions that refer to errors. If you don't download the Errata, you can get the question wrong even though your book says you're right.
And when you bid a job and ask for an inspection using a Code error?I passed the New Jersey Exam, I'm good for now! :thumbup:
He will underbid the guys who know the code and the inspector will never say a word. I lose work to code violations constantly around here.And when you bid a job and ask for an inspection using a Code error?
Not all errors result in a lower bid.He will underbid the guys who know the code and the inspector will never say a word. I lose work to code violations constantly around here.
Very true. Just got burned though so I'm feeling bitter.Not all errors result in a lower bid.
Heres a doozy from an old Australian Wiring Rules,Supplement for factories using American Equipment if using the center tapped delta system the neutral shall be identified according to US practice,the white wire however it may be any colour except green.Another one after going thru current transformers the B phase shall be indentified as C phase and vica versa,Why?
