That would be cool but where do you stop if you start building structures to withstand aeroplane impacts? We have enough overengineered crap like 32mm reo on 200mm centres just for seismic issues.I would have liked it better if they just rebuilt it as per the original blueprints but just a bit stronger.
Some people believe that if you can't do something 100% effective you should give up, I disagree. As long as the marginal increase in utility gained by added fortifications exceeds the marginal cost adding fortifications then it makes sense to do so.That would be cool but where do you stop if you start building structures to withstand aeroplane impacts? We have enough overengineered crap like 32mm reo on 200mm centres just for seismic issues.
