Status
Not open for further replies.
1 - 2 of 2 Posts
currently wiring up an outbuilding,approx 60m away from main db,new 8 way cu goinig in outbuilding 1x 32a ring,1x 6a int light circ 1x 6a ext light circ 1x16a water heater circ 1x 6a security circ 3 spare,now ive been out the game 10 yr tho i done the app'ship and got jib card etc before going into security..and ive forgot loads already..the load on new outbuilding cu will be around 18a max(customers rating)iam thinking of running the supply from a spare 32a mcb on main power cu (theres 2 cu's already 1x lighting cu and 1 x power cu both protected by a 100ma td rcd the power board also has its own 30ma rcd) to the new cu,but with regards to earthing the supply and the new building do i supply new rod/ or use exsisting earth from main cu rod/ or connect both rods together/ earth the supply cable only from the main cu/ and use the new rod for earthing the outbuilding only..:confused1: i knew i should have stuck with sparky'ing:mad:
Thanks for posting on ElectricianTalk.com. The Moderators/Admin of this forum would prefer if you post Do It Yourself related topics on our sister site www.DIYChatroom.com
As stated in the sign up page, ElectricianTalk.com is designed for electrical industry professionals to discuss issues and topics related to the electrical trades and related industries. Many of our professionals are also members at DIYChatroom.com and are looking forward to assist you with your needs.
Please take a moment to post your question at
www.DIYChatroom.com If your not already a member of DIYChatroom.com you can sign up for a free account by going to http://www.diychatroom.com/register.php/
1 - 2 of 2 Posts
Status
