The NEC makes no distinction between horizontal and vertical runs of raceways.
my pipe is straight up in the middle of the room above a switch gear.. support to what and with what is my question... there is nothing around this gear for about 12 feet. i cannot build anything on or around this switch gear.. thanks again for you input greggIMO, the exception to 358.30 (A)(1) is to be used when there is no means of support within 3' of the box. So if I understand the situation here correctly you will need at least (2) straps for your 7' piece of conduit.
thanx greg i have done this before but it looks bad.(my opinon) a plumbing inspector said that was the first time hes ever seen that. no one made us change it though. so i thought there was a different way to do it that looked better. thanks for the input greggIf you have a beam, you can run a piece of all thread down and clamp the pipe to it.
thanks MDSkunk that was the answer i was looking for. i'll cheak out the supply house mon.They make strut that has holes in the sides as well as the bottom like normal. This way, you can hang a short piece of strut from all thread and have the open side of the strut against the conduit to use regular strut clamps to fix the conduit to the strut. I can't remember the brand name now of the stuff with holes in all three sides, but I think it's only one or two companies make it. I've never really had any trouble getting some when need be. For shorter conduit drops, I have already just used a piece of strut vertically, fixed to the beam with a beam clamp at one end, and the gear or floor with an angle bracket at the other end. Fix the conduit to the strut with a hanger or strap of your choice.
Can you just drill out holes on the sides of a regular strut for the allthread? Or it will be considered a custom modification that won't pass?They make strut that has holes in the sides as well as the bottom like normal. This way, you can hang a short piece of strut from all thread and have the open side of the strut against the conduit to use regular strut clamps to fix the conduit to the strut. I can't remember the brand name now of the stuff with holes in all three sides, but I think it's only one or two companies make it. I've never really had any trouble getting some when need be. For shorter conduit drops, I have already just used a piece of strut vertically, fixed to the beam with a beam clamp at one end, and the gear or floor with an angle bracket at the other end. Fix the conduit to the strut with a hanger or strap of your choice.
Don't hang the EMT 1'' from the ceiling, just stub out a 90 on top of the switchgear, and hang allthread 7' from the ceiling.i need to run a control wire to a swith gear in 1/2 1nch emt from the ceiling for a kw meter. the gear is in the middle of a room. from the top of the gear to the ceiling is 7ft. code states support every 5ft. art. 358.30 (a)exception 1. is this artical for vertical also? if it is what is the best and or easyest way to do it? thanks for your time gregg
I I I I
I I I I
