I'll usually use either a true 3 gang box (ususally special order), or deep cut in boxes that chain together.What are you guys using for a 3-gang switch box when using MC as the wiring method?
Thanks,
Cruzie bars...they span the studs and clip the ears. (I don't know the official name for them)I assumed it was new work. How do you mount old work cut-in boxes? Just screw thru the side into the metal stud?
Does the spacing work out right for a 3-gang switch cover?
No, it doesn't.Does the spacing work out right for a 3-gang switch cover?
(and yes, it's new work)
Nope, separate cover plates.Does the spacing work out right for a 3-gang switch cover?
Hence the name "Hack Work"Nope, separate cover plates.
Ok, this would be my last choice.
ie: high profitHence the name "Hack Work"
The customer.He asked about MC, this is probably commercial, who is gonna give a flying fu(k (other than the electrician)?
Yes, we must have different customers. Not a single customer has ever cared about having multiple cover plates, it's the absolute last thing anyone would notice. I am talking about in hospitals, offices, data centers, etc.The customer.
Maybe we have a different type of customer than you,
I know that just using what's laying around is easy, and I very much see your point but, it's not for me. It just looks like poor planning or an after thought when I see three or four switches installed like that.Yes, we must have different customers. Not a single customer has ever cared about having multiple cover plates, it's the absolute last thing anyone would notice. I am talking about in hospitals, offices, data centers, etc.
Triple brackets, 1900 boxes, and 1 & 2 gang mud rings are on the job, ready to go. On the other hand, look at this thread as an example of how many different hack solutions people have had to come up with to do this installation with 1 cover plate. It's not worth it, especially if the supply house doesn't have the 3 gang mud ring or that type of box to fit it or whatever.
Just my experience.
Those are really tight and I hate to find that when I open a switchbank.Gangable gem boxes here. Usually get a box of the new work ones and a couple boxes of the old work ones.
You see it that way (I do too).I know that just using what's laying around is easy, and I very much see your point but, it's not for me. It just looks like poor planning or an after thought when I see three or four switches installed like that.
I do see why it's done like that, and it works just fine.
