Me, homeowner, electrical inspector.Who would ever know?
I just swapped a 225 main and a 200 main. The 225 panel had more spaces and I needed them in the 200 amp panel. Both cans are rated 225.Chris1971 said:Would it void the UL listing if you took the exact same panel guts (main breaker and bus section) from the same manufacturer and replaced them with new?
Existing panel is 6-7 years old. I believe I can get the exact same panel and just swap the internal parts. (Main breaker and bus assembly)I just swapped a 225 main and a 200 main. The 225 panel had more spaces and I needed them in the 200 amp panel. Both cans are rated 225.
Have you checked with the manufacturer? I actually found Eaton to be very quick in responding to a question I posed to them last year.Existing panel is 6-7 years old. I believe I can get the exact same panel and just swap the internal parts. (Main breaker and bus assembly)
Thanks. I will do that tomorrow.Have you checked with the manufacturer? I actually found Eaton to be very quick in responding to a question I posed to them last year.
If you are indeed using an Eaton product, here is the link (click the technical question link):Thanks. I will do that tomorrow.
I'm glad you responded. It's actually an Eaton Cutler Hammer BR series panel. 150 amp MB. 30 cir.If you are indeed using an Eaton product, here is the link (click the technical question link):
http://www.eaton.com/Eaton/ProductsServices/Electrical/Support/CustomerSupportEatonCare/index.htm
I chose to message them last year.
No, it would not void the UL listing.Chris1971 said:Would it void the UL listing if you took the exact same panel guts (main breaker and bus section) from the same manufacturer and replaced them with new?
I'll call the manufacturer in the am to verify.These days, simply opening the cover voids the UL listing........
As noted, often the interior will specify which box can be used, or the box will specify which interior.
You might need to go to their website and check which boxes are allowed with which interiors.
You are totally making this all up.Chris1971 said:Update: local AHJ will not allow internal components to be replaced. He interprets it as a modification that voids the UL listing. Looks like we'll be replacing the whole panel.
