Status
Not open for further replies.
1 - 2 of 2 Posts
In my bathroom I have a switch and outlet combination. The switch controlled an overhead light. The outlet is a 120 volt outlet receptacle. The switch went bad. I bought a new switch outlet combination. A person learning the profession replaced the switch outlet combination. From all outward appearances it looked like she did a good job. The switch controlled the overhead light. But I noticed that the switch controlled the light and the outlet. The only way I could get 120 volts on the outlet was to turn the switch to the on position. The fin was intact and there were 3 cables. I don't remember if this was wired like this before. The inside of the cardboard box the switch outlet came in had two diagrams depicting two ways to wire it. One said separate feed break off the fin. It showed the switch controlling the light independent of the outlet. The outlet according to the diagram always had 120 volts. It showed the L cable going to one side of the switch and a cable connecting to the opposte terminal I assume going to the light. It showed anothe pair of cables going to the bottom terminal and another cable going to the opposite terminal indicating 120 volts always across the outlet. A total of 4 cables. I like it this way because I can always have my phone and my toothbrush charged. The second diagram said common feed fin intact, power outlet for grounded applications. It showed first the fin intact. It had 3 cables. One L cable going to the top terminal. One terminal going to the oposite terminal which was common to an unused terminal and the 3rd cable I assume was the return. My guestions: (1) What is meant by "Power outlet for grounded applications?" (2) Is there any elestrical code that would prevent me wiring it so that I have the switch that controls the light independent from the outlet where the outlet alwasys has 120 volts or in other words have the so called "Separate feed?"
· I own stock in FotoMat!
Thanks for posting on ElectricianTalk.com. The Moderators of this forum would prefer if you post Do It Yourself related topics on our sister site www.DIYChatroom.com
ElectricianTalk.com is designed for electrical industry professionals to discuss issues and topics related to the electrical trades and related industries. Many of our professionals are also members at DIYChatroom.com and are looking forward to assist you with your needs.
1 - 2 of 2 Posts
Status
