1 - 17 of 17 Posts
Electrical Simpleton
Are you asking if the NEC requires this? Or, is this a question driven by DOE requirements?
Pete
Coffee drinking member
MEISENBURG said:
a commercial building where there is a office with more than one light fixture, do they need to be controlled separately. Thanks
How many entries are there from a hall or outside?
animal lover /rat bastard
I must not understand the question. I've seen offices where hundreds of lights were controlled by one switch.
like Pete said, federal/state/local energy codes require occupancy/vacancy switching also.
1 - 17 of 17 Posts
