I have a production line that contains 3 separate pieces of equipment, let’s call them A, B, and C. Parts are transferred from A to B and then from B to C. Each is driven by its own separate motor controlled by their own Siemens VFD motor drive. A and B are synched speed and position using a 3rd device called a Synchron Controller made by a German company Mall+Herlan model Gleichlaufregler GLR 2.1. This works good for speed and position for A to B where B is the master and A is the slave. Its takes an analog speed input from B drive, outputs an analog speed to A drive, uses 2 input pulses one each from A and one from B, 1 pulse equals 1 cycle. Drive B is set up to run at a constant speed while drive for A uses the analog output from the synchron controller to adjust the speed. It uses the inputs to position them in time.
I need to do this for B to C. Currently, B and C are not synched up but I need to synch them for better production and to reduce scrap. Has anyone ever heard of the Synchron Controller mentioned above, I don’t have any info nor can I find anything on the internet about it? Does anyone know of something I can use that does the same thing? Having a hard time finding anything that does not use encoders.
The line runs 84 pieces per minute so it’s not that fast. Is there a better easy way to do this? The entire line is controlled by a Siemens S7-400 plc but it does not have analog output module. Just think adding a 3rd controller between B and C would be least expensive and easiest.
Any help or advice on the subject would be greatly appreciated.
