T5
501 Views 10 Replies 6 Participants Last post by  joe-nwt
T5 screws what are the difference between these two
Household hardware Nickel Engineering Screw Metal
1 - 11 of 11 Posts
I use ones that look like the one on the right. Even the same finish. I think they were "TEKS" brand, but I bought a large quantity a long time ago. On mild steel you could drill/tap several holes with the same screw.
The one on the left looks.........cheesy somehow. Is it any good?
The difference? About $.15 each. And amazingly, the ones on the left actually work quite well. I was surprised the first time I used them. In some steel they actually work better than the cut ones.
Sent from my SM-S908U using Tapatalk
  • Helpful
What brand?
What brand?
The cut ones were Fastenal. The stamped ones are bulk off Ebay. I dont do that purchasing so I don't have a brand for you.
T5 screws what are the difference between these two View attachment 176502
Left is electro galvanized.
Right is hot dipped galvanized, for a more robust environment.
Reactions: 5
These are Fastenal. No idea on cost
Those are regular self drilling screws, the Tek 5 type point will drill through an I-beam flange. They are a lot more expensive.
Those are regular self drilling screws, the Tek T5 type point will drill through an I-beam flange. They are a lot more expensive.
These drill pretty good, in the drawer above
Brown Wood Grey Flooring Hardwood
Reactions: 3
I've tried both and I haven't had any problems with the eBay ones, but I remember a thread a while back where people got some clunkers off eBay. The genuine ITW Teks are a lot more expensive but they're still less than beam clamps. Teks® 5 Steel-to-Steel Self-Drilling Screws On ITW Commercial Construction - North America (itwbuildex.com) I buy the #12 x 1-1/4" and 12 x 1-1/2" but it would be great if they made the 1/4" in a shorter length.
Here's a pro tip, if you drill and remove the #12 Tek-5's, you can redrill and tap it with a 1/4" x 20 combo drill-tap super easy, and you'll get several holes per Tek-5. I like this because I can use short screws and you don't have those dagger points sticking out the other side.
  • Helpful
Reactions: 3
I just buy the 1/4" Teks and be done with it. The screws are worth about 30seconds of my time at the rate I charge, I can only play around with them so long.
1 - 11 of 11 Posts
