Thats perfect! Thanks. Its weird their Mark 7 series requires additional control wires. Wonder why they dont eliminate it since the Mark 10's do not require any? Who wants to run extra wires?!theloop82 said:These are actually the best dimming t8 ballasts i have used. They arent too complicated as they use existing wiring and switching (you have to use their dimmer of course) and depending on what fixtures you are retrofitting you may have to change the tombstones (cant be shunted) Mark 10 - http://www.stanion.com/pdf/advance2.pdf
I beleive the 28w is the "eco" version of a 32 watt. is it in a 4' troffer? If so its all good because that's the ones i was doing. Just make sure you pay attention to the tombstones.Thats perfect! Thanks. Its weird their Mark 7 series requires additional control wires. Wonder why they dont eliminate it since the Mark 10's do not require any? Who wants to run extra wires?!
Not sure any of their ballasts will work with my 28 watt/ t8 lamp. Says 17, 25, and 32
