OP is in Canada...I'd use a 30 and #12. Yes, it's code compliant. Since you're an apprentice, you should have access to a codebook so you can look at articles 430 and 240 to see that using #12 with a 30 amp breaker is legal with a motor.
That motor doesn't have any overload protection. Article 430 states that O/L is required so you'll need to provide it separately. A single phase motor starting switch with O/L built in would be the easiest. I usually use the Square D 2510 class.
Please take a few minutes to fill out your profile. Here's a link to help you do this quickly.Hey guys I’m a newbie in the trade first year. So to wire this table saw to work properly(115 volts) I would need a 20 amp plug and 20 amp breaker right? With 12/2 wire? View attachment 154062
Canadianized it for you!I'd use a 30 and #12. Yes, it's code compliant. Since you're an apprentice, you should have access to a codebook so you can look at section 28 to see that using #12 with a 30 amp breaker is legal with a motor.
That motor doesn't have any overload protection. section 28 states that O/L is required so you'll need to provide it separately. A single phase motor starting switch with O/L built in would be the easiest. I usually use the Square D 2510 class.
So no over load protection is required in Canada? our SH’s carry 40/2 breakers, they are also on eBay.Canadianized it for you!
Ideally I would wire it with a 20A breaker and #14 wire at 230V. At 115V, a #12 will work for wire and the 30A breaker is a good start. By code you could put it on a 40A breaker if you needed too, but good luck finding one.
Being a grunt it’s been awhile since I had my head into code but aren’t we supposed to multiply the fla (18A if it’s going to be 120v) by 125% and go with the minimum ga conductor/ocd above that? In that case it’d be #10&30A ocd?Canadianized it for you!
I would run ten Guage. But more likely I'd put a 240 receptacle in, that's a big shop saw so it's not getting moved around all over the place.Being a grunt it’s been awhile since I had my head into code but aren’t we supposed to multiply the fla (18A if it’s going to be 120v) by 125% and go with the minimum ga conductor/ocd above that? In that case it’d be #10&30A ocd?
Thanks!Canadianized it for you!
A single phase dual voltage motor with built in O/Ls will have 7 (or more) leads. This one has 6 so no built in O/L.Take your motor ampacity and multiply by 125% and that will tell you what ampacity you need for your wire. Assuming the motor has overload protection built in then you can use an overcurrent protective device at 250% for the nec. I bet it is similar for the CEC, if not then canada is wrong...LOL
The wiring diagram looked a little off, now I know why.A single phase dual voltage motor with built in O/Ls will have 7 (or more) leads. This one has 6 so no built in O/L.
Get used to questions that is how you learn, the more information you give up front is better then we don't have to guess.Hey guys I’m a newbie in the trade first year. So to wire this table saw to work properly(115 volts) I would need a 20 amp plug and 20 amp breaker right? With 12/2 wire?
First and foremost thanks for the reply I need all the help i can get . Sorry for the confusion from my initial post.Couple of questions
1. Is this for you? If so just run it on what you have.
2. Does it have a starter or switch installed?
2. Terminology. You said you would need a "I would need a 20 amp plug and 20 amp breaker right? With 12/2 wire"
This is why you got a variety of answers, You talk Plug when I guess you meant receptacle. If it was Plug then it would be 12/3 cord not 12/2 wire.
Good job asking the questions here and not just guessing.
Cowboy
What brand of panel?First and foremost thanks for the reply I need all the help i can get . Sorry for the confusion from my initial post.
1. It is for my buddy in a garage. it just keeps tripping the breaker with what it currently has. A 15a cord end as shown in my attached pic. The cord wire is 14awg.
2. It has a switch installed.
3. Yeah i meant what kind of receptacle do i need to install for this saw. I really just don’t know what this needs to run properly. What kind of cord end? What size of wire, what kind of receptacle. Oh man. so many questions.
