What about hardwiring a microwave?No.
There are times where you can tap an oven circuit for a stovetop unit but you cannot supply a 15 or 20 amp receptacle with a 40 or 50 amp circuit.
So the overcurrent is 40/50 Amp but your wire is a #12? What is the ampacity of #12? NO NO #12 is for 20 Amp (#14 for 15 Amp, #12 for 20 Amp, #10 for 30 Amp, etc.)I have a potential customer that has a range (or oven) with a wire for a hood fan above it. - They wanted to get a new microwave hood to put in place of the old hood fan.
I suggested they run a new circuit because the old hood fan appeared to be on the kitchen receptacle circuit with all the other counter top appliances. - I am wondering if it is acceptable to tap off of a 40A or 50A range branch circuit for an appliance like this, (Using #12). I have seen this done before but I do not really know the rules for doing so. I looked at 210.19 (A)(1)(3) Exception 1 and it looks to me like this is acceptable. However, I have never done this or seen anyone else do it. I have only encountered it in older homes done by who knows who?
Half your cooking times, run you micro on 240 :nuke:What about hardwiring a microwave?
Only in ice fishing shacks.What about hardwiring a microwave?
Taps are always conductors rated less than the overcurrent protection and the NEC allows that for many things.So the overcurrent is 40/50 Amp but your wire is a #12? What is the ampacity of #12? NO NO #12 is for 20 Amp (#14 for 15 Amp, #12 for 20 Amp, #10 for 30 Amp, etc.)
Are you familiar with tap rules?So the overcurrent is 40/50 Amp but your wire is a #12? What is the ampacity of #12? NO NO #12 is for 20 Amp (#14 for 15 Amp, #12 for 20 Amp, #10 for 30 Amp, etc.)
You may want to look at 210.19(A)3 and 4 including the exceptions.There isn't any tap rules for branch circuits, only tap rule for branch circuits applies to a clock recept above the stove and was written in the 60's
That's not a tap rule. It just allows for that outlet to be on the small appliance circuit.There isn't any tap rules for branch circuits, only tap rule for branch circuits applies to a clock recept above the stove and was written in the 60's
Sure there is. One example for example allows, with conditions, an oven and cooktop to be split off the same circuit. This is never done anymore because of changes in modern wiring methods but it is still allowable.There isn't any tap rules for branch circuits, only tap rule for branch circuits applies to a clock recept above the stove and was written in the 60's
Dont have my CEC but that rule has ot do with allowing you to go one conductor size smaller for a last in line heater, as long as the heater isn't more than 20-25% of total circuit amperage.Are you familiar with tap rules?
I learned them in school and I still don't fully understand (our) tap rules.. but you can do some fantastic stuff if you do understand the rules.
Like pull #14 for part of a big heating set, that is on a 30A breaker.
