1 - 4 of 4 Posts
Uh oh, a Canadian asked a question in a non-Canadian forum.
The sheeeeeeeit is going to hit the fan!
Anyway.. I've never heard of a connector/coupling to just attach the metal/rubber coating.. if I get a rip or tear, I just tape the heck out of it. What is the situation you have?
If the cable has pulled out of the connector and needs to be repaired, such as with settling when ran underground, I've installed either a conduit nipple or a length of conduit to a coupling then re-cut in the cable... For an armor and outer rubber repair, nothing I can think of off hand..
Contact the wire manufacturer and they can give you their method of repair that will still give you the same classification rating. Just had to repair a cable in some tray here. 2 layers 88 2 layers 33 and a huge piece of split shrink for a boot.
1 - 4 of 4 Posts
