CEC 12-602 / 12-902 I’m an industrial electrician, but in a commercial setting in a car dealership an owner was asking how much it would cost to run Teck cable around his chain link fence (270 feet) to throw in a 30 amp plug or install a 60 amp sub panel. I of course told him he will be cutting concrete and going underground as I’m doubtful directional drilling is cheap for the 20 feet of concrete.
Is running Teck on a fence through conduit meet the cec requirements even though you need to free air the cable for a bit for rule 12-902(2)ii
My experience: Fence along a canal to keep people from falling in, not too bad, ran rigid conduit on that before and it's still there after thirty years. Still working.
Fence along parking lot- In under four years enough cars backed into the fence to cause the threads to get pulled out of the couplings in a couple of places and the wires got exposed. They were only RG-11 coax so no shock hazard , but it was a bad idea to run along the fence instead of trench and bury. (Customer wanted cheap route).
Well the fence post are 8’ apart so above the 2 meter strapping requirements. So since there is nothing on the outside of the fence to damage the cable, I could run it out there since no vehicles have access to it. I would just use treated wood strap the cable and give the lease holder the cheapest option if I could. But there just doesn’t seem to be any clear rule on strapping Teck cable to fencing. It just mentions portions of buildings.
I have emailed the safety department also but I have heard nothing back yet.
But from working in my sawmill days. We strapped Teck cable everywhere Used trays where we could, and never had any issues other than replacing older installations that forklift operators crushed.
I'd zip tie the teck to the fence and be done with it. If its not subject to mechanical protection requirements, its an easy job that I'd have done before ESA gets back to you.
If it needs mechanical protection (such as from vehicles) then that's a different story altogether.
The inspector got back to me. The fence is not considered permanent structure so the Teck cannot be strapped to it. Only if it is a temporary install. Client is in the works of working on getting a trench dug.
Yes there should be more clarity on what is considered a permanent structure. My guess is it is continuous concrete. But every time that I ask for clarity through email I get told to call. So to me there need to be a bit more to the safety authorities per region clarifying what qualifies as a permanent structure. Since most structures in regions under 1000 square feet don’t even need a building permit. Essentially it seems to be up to the inspector what he/ she deems permanent from what I have experienced. It’s just a tough battle sometimes between losing the work cause the property owner will just find some handyman to just hook up the panel / plug because the cost becomes to high to adhere to the code.
In Ontario, a building (such as a shed) doesn't need a building permit if it's under 108 square feet...
Just because a building doesn't have continuous concrete foundation doesn't mean it isn't a permanent structure. My dad is getting plans for an addition that we are using sono tubes for... it it was not a permanent structure we wouldn't require electrical in it... @emtnut I was just talking about this with the neighbors... they jack houses up and move them all the time!
I've seen teck cable attached to things other than houses all the time... such as a fence, or a deck, or a dock...
1705.01.1.4. “Permanent fence” means any fence, other than a temporary fence as defined
herein.
1705.01.1.5. “Residential fence” means a chain link, wood picket fence, wood post and rail,
brick, masonry, stone, hedge fence, and similar materials of a permanent nature, such as wrought
I’ve put Teck on a fence before. It’s beautiful. It’s really really great. It was along the US border fence. The electricians on the other side threading rigid were so jealous [emoji38]
I have seen fences I wouldn't trust to put a birdhouse on, and others that are going to be there a long time after the house falls down, so to me it depends on the fence.
A strong fence is a rarity in our time.. They are usually placed in the backyard, for example, for convenience or to prevent children from sneaking up and getting into someone else's territory. I don't trust people very much, and I really wanted to put up a good strong fence after my house was robbed. This fence was not designed for any protection, it was easy to climb over it and enter through the kitchen entrance. I made an order for https://www.walshlandscaping.co.uk/services/fencing-contractors-maidenhead-ascot/, where really put a reliable and stable fence. I no longer worry about thieves breaking into my home, and now my security has increased.
Is there a pipe running the length of the fence to hold up the chain link at the top?
I've found cables run inside that pipe.
No one at the time could tell me if it was acceptable by the NEC.
Related Threads
Electrician Talk
2.3M posts
93.3K members
Since 2007
