Most terminals, bus, or breakers, I see a 75 C rating. So for an example using the wire table for 50A Thhn, I can use #8 Cu. Today I checked the sub panel bus rating, and it was 75 C, After I pulled in the wire, and opened the control box near the landing lugs, I found the sticker with the data, and it said 90 C wire required !!!
You guys check, or use the 75 C or 90 C on your pulls ?
To me that seems like they wanted you to use 90c for the heat, but the 60c column for amps.
I am old school and always use the 60c column for 100 amps and under 75c for anything over. I don't think the size difference under 100 amps is going to break the bank, and I know I'll never run into a point where I'd have to change it because it's to small.
I can't remember sizing to the 60C unless I'm running Romex or SER???
Related Threads
Electrician Talk
2.3M posts
93.3K members
Since 2007
