So, changing out a panel. What do you usually do? Turn off the main breaker for the panel in question. Lock out and tag it? Then double triple check the target panel for voltage next after removing the panel cover? I bet most every one of us at least double triple checks for zero voltage on the panel in question, who wouldn't? Me, I use my wiggle or fluke and check everything. Then I run my volt tick around the panel in case something is fed from elsewhere and is just traveling thru the panel and fed from elsewhere. Usually that step comes out when there is a whole lot of wires in that panel and not easily visible to follow all wires to see where they come from to where they land.
But that panel might still not be safe to swap out yet.
What are you talking about macmikeman? Is this another conspiracy story? No.
Here is the last test to make which no one does, except for me now since I got a nice little whack a few days ago while swapping out a residential panel. Take out your clamp on amp tester and test for current flow in the neutral feed and the ground feed to the panel. See? I never used to do that one step. I will from now on. The panel I pulled the other day had neutral current (4.5 amps to be exact) running on it even after killing the sub panel breaker. Whoda thunk? Unscrewed the 2 hots and pulled em out of the main lugs. Then I loosened the neutral feed and while grabbing it to pull it out somehow or other touched the uninsulated end of the wire with one hand and was holding on to the panel for leverage with the other hand and bingo, right thru the heart path. Hand to hand. I'm quick to let go . No big deal. (time for comment boys, have at it).
Up in the attic in a junction box, I found where there was a circuit from the panel I was working on mixed with a circuit splice from another sub panel in the house. All of the neutrals in that junction box were tied together. I found it quick because when I opened the neutral and got whacked, after that the lights in the area on the floor above me in the kitchen , dining , and living room went out. So I knew where to go looking and found it.
So I am taking the time now to put this out there- AMP TEST THE WIRING BEFORE YOU BEGIN TO DISASSEMBLE , VOLT TESTING IS NOT ENOUGH.. And also a tipoff is multiple sub panels , that is something to look for when changing one of them.
