1 - 16 of 16 Posts
felonious smile.
Went to a laudromat to add circuits for clothes dryer upgrades. I should have snapped more pics at the hackmanship but here is what would normally take me 4 hours took me 7. i had to pull a second circuit to 5 single clothes dryers getting upgraded to doubles. Just a matter of pulling in new conductors, swapping breakers and switches from single poles to doubles and installing 3 wire whips. easier said than done when dealing with long island workmanship. I bet the original installer was all happy with himself thinking what a nice job he did.
Reactions: wildleg
felonious smile.
Discussion Starter #2
Trouble downloading pics
felonious smile.
Discussion Starter #7
11/2 wiremold system with the toggle switch disconnects recessed into it. I'll try downloading again. FAILED.
Gotta switch this thing back to tapatalk
felonious smile.
Discussion Starter #8
Aren't you the guy who roughs jobs with the intent of screwing the next guy?
I often leavesomething mislabeled so if the GC screws me he only ends up screwing himself and customer and whoever takes on the job.
I've just started frontloading my rough-in bills. This helps ease my nerves when I don't hear back from them for the trim out.
felonious smile.
Discussion Starter #10
Ok tapatalk is back.
felonious smile.
Discussion Starter #11
felonious smile.
Discussion Starter #13
It's the wall bejind the dryers. Stuff sucks with the devices incorporated in it.
Reactions: 360max
In the one pic, it looks like the flex is snuck in behind the black pipe and is touching... Is that a gas line? Would that ok by NEC?
felonious smile.
Discussion Starter #16
They had the BX whips taped to the gas hoses. Using two separate single pole switches to control one double stack unit fed with a 3 wire whip. A 1 1/2 " emt run is terminated directly into a 3"x3" wiremold end box. Over the suspended ceiling all j boxes are screwed into the ductwork. This is a typical long island hack job which had Ray Charles as an electrical inspector.
Reactions: glen1971
1 - 16 of 16 Posts
