You would also lose a phase on the wye sideWhat should be expected to happen when a Delta Wye transformer losses a phase on the delta side ?
:whistling2:
Any voltage drop on the other phases ?You would also lose a phase on the wye side
If they're a common core, it's almost certainly gonna result in a L-L or L-G fault and take down the entire transformer.
Could be anything. How do you know the primary was Delta wye, some pole pigs and 3 phase pad mounts are Ygr Ygr. Just asking.Today i saw a Δ:Y transformer with a blown fuse on the primary side. All the loads connected to the secondary are L-N loads. every thing that was supplied by the transformer was not running smoothly, clearly voltage fluctuation, all the lights where dimming and brightening. but the transformer was still running even though the fault wasn't repaired at that time. I wasn't there to witness the repair.
The transformer is a common core type
I am not sure if there was a dead phase on the secondary. But as far as i know is that the blown fuse was caused by an overload.It's hard to say what was happening there, because a blown fuse on the primary doesn't necessarily mean that there was a transformer winding fault, it just means you're missing a phase, and I'm not sure how a closed Δ:Y would behave if it single-phased.
Was there a phase dead on the wye side or was everything still running, just acting strangely?
A pole mounted jug transformerWatts a pole pig???
Watts a pole pig???
This is a picture i have from the transformer.Could be anything. How do you know the primary was Delta wye,.
This will help. It shows the various voltages on a secondary 3 phase bank after a primary phase breaks open:I am not sure if there was a dead phase on the secondary. But as far as i know is that the blown fuse was caused by an overload.
